Ga door naar hoofdinhoud
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Vragen Bekijk alle
Kernel_task greater than 100%.
I upgraded my memory to 16GB and now the fan runs constantly and the kernel_task is greater than 100%. The screen no longer works and I may have damaged the screen connector, so I am using an external monitor. Needless to say, my upgraded machine is much slower than when it was 8GB.
Update (10/18/2021)
Thanks for the answer. Unfortunately my display connector seems to be damaged.
Is dit een goede vraag?
2 opmerkingen
@miwhite - Can you post a few pics so we can see the problem. We might be able to aim you to the needed part/s.
If you think this is beyond your skills set thats cool! If you can give us your country and nearest city we might be able to aim you to someone who can help you.
door
Thanks Dan. I live in Ottawa, Canada.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ouch! From the frying pan into the fire.
Sadly the display needs to be connected as there are sensors within it which SMC needs to get there input. Without them SMC goes into CPU Safe mode ramping up the fan and lowering the CPU’s clocking. Which is why things are messed up.
Can you post a few pics so we can see the damage Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Michael White zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 36
