Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
20 Vragen Bekijk alle
iPod will not respond to play button.
For any kind of playback, the play button does not work. I can scroll, go through menu selections, but when I press the play button, nothing happens.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
I’m not familiar with the iPod classic however you problem seems to be a common one.
From what I could find online this is a common problem people come across with their iPod classics after using them for some time.
It seems that after sufficient use, the click wheel will simply stop working (in your case, just the play button.) other people have had the entire click wheel stop responding at once.
The only solution I have been able to find requires the replacement of the click wheel.
Luckily it is fairly easy to find replacement click wheels for iPod classics’. Replacement parts are avalibe here on ifixit (link below, with guides for replacement) but are currently out of stock, it shouldn’t be to hard to find them elsewhere should you not want to wait till the part is restocked.
Hope this helps!
Link to replacement scroll wheel: iPod Classic Click Wheel
Guide links: iPod Classic Click Wheel Button Replacement
iPod Classic Click Wheel Replacement
Replace a broken or damaged click wheel for your iPod Classic with this part. This product does not include the button and can be identified by 821-0545-A printed on cable. Afbeelding
Product
$12.99
iPod Classic Click Wheel Button Afbeelding
Handleiding
Moeilijkheid:
Zeer moeilijk
30 minutes - 1 hour
iPod Classic Click Wheel Afbeelding
Handleiding
Moeilijkheid:
Zeer moeilijk
1 - 3 hours
Was dit antwoord nuttig?
Voeg je antwoord toe
Robin Clamme zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 204
