Ga door naar hoofdinhoud
75 Watt 8" Subwoofer. Part of Boston Acoustics Micro90t 5.1 home theater package.
6 Vragen Bekijk alle
Woofer on one tower speaker rattles with deep, loud bass
The 10 inch woofer on one tower speaker (Boston Acoustic T930) rattles with deep, loud bass. I replaced the foam on this woofer and did not do a perfect job leaving a slight ripple in the foam. Could this be the problem, or is the cone or speaker likely damaged? Other than on deep, loud bass the speaker sounds fine.
Is dit een goede vraag?
1 Opmerking
I also found several small sections of the foam that were not snugly secured to the speaker, so I added glue there, and all seems ok so far.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
something could be rattleing from within it make sure all the screws are very tight because the bass will loosen then other long periods of time
Was dit antwoord nuttig?
Voeg je antwoord toe
John Faulstich zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 120
