Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
20 Vragen Bekijk alle
SE first generation help please.
Hello everyone,
I recently changed my battery on my SE but since my volume buttons, top lock button, light and vibrate functions haven’t worked. Does anyone know what I’ve done?
many thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like the volume flex cable is damaged.
I’s have to doublecheck, but I may connect to the power button, flash, and vibrator. It has been a while since I’ve replaced that part.
It’s fragile and is installed around the battery.
I hope this helps
Was dit antwoord nuttig?
1 Opmerking:
Many thanks for your help. Would you know where I can find a video on fixing the said issue. Many thanks again for your knowledge.
door
Voeg je antwoord toe
Ada Rose zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 54
