PS5 SSD installation - replacement screw and spacer
I tried to install a new WD SN850 SSD in my PS5 last night. However when I went to remove the screw and spacer in the bay, the screw was stuck, and I just can’t remove it at all. I’m looking for a replacement screw and spacer to fit the SSD. Does anyone have any recommendations from Amazon UK or any other retailer? I’ve contacted Sony, but they haven’t got back to me at all, which isn’t a good sign. Many thanks in advance.
Is dit een goede vraag?
9 opmerkingen
I got the same problem too. Currently trying to find similar screw and spacer in SEA market but can't find nothing
door Akifan Jannata
@Akifan Jannata I still haven't had a response from Sony Customer Support. I'd happily buy the screw and spacer if I knew what I was looking for! So frustrating!
door Kevin McCubbin
Hi i have the same probleme if one of you find the good dimension for the screw can you tell me
door Loic Piguet
To replace the screw that holds down the M.2 access cover, use a M3 × 16 screw.
To replace the screw that holds down the M.2 SSD drive, use a P3 × 10 screw.
To replace the spacer that supports the M.2 SSD drive, use a spacer with the dimensions φ5.5 x 3.95 mm.
door m gadzikowski
Where do they sell the spacers? I can't find it with an internet search.
door Nelson Alvarez
4 commentaren meer tonen
