Ga door naar hoofdinhoud
The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic. It was released in January 2009 and discontinued in 2011.
'charger is not supported' message comes
when i am connecting the charger to the phone there is "charger is not supported" message comes..then i had tried with different charger.but the same message comes and my phone is not being charged.plz any one help.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
meghna gayen, check on here seems like a common problem. Looks like changing the 47k resistor works for most people. Of course make sure that you have the charger for your phone...;-)
Was dit antwoord nuttig?
Score 1
Nokia 5130 charging not supported.
Solution is here now
Score 1
1 Opmerking:
Mehak Mahoo, same solution as above.....;-)
door
Change the battery
Change the battery if you repair you battery after some time this problem come again and again so kindly change your battery
Voeg je antwoord toe
meghna gayen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 5,343
