Ga door naar hoofdinhoud
The OnePlus 8T is an Android smartphone manufactured by OnePlus, released on 16 October 2020.
13 Vragen Bekijk alle
Stuck in fastboot, need help getting into EDL
I was trying to flash a stock rom via fastboot, flashing img files but one file was corrupt. I need to get into EDL mode but can't, it is now stuck booting into fastboot. Is this something you can do? I know you can do it by shorting test points on the motherboard but I not comfortable doing that
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Since you're bootlooping into fastboot, you can try download 8T Fastboot ROM to unbrick it ( if ur bootloader is unlocked ). If not, besides of using testpoint on the mainboard, you can purchase deep-flash cable ( around 2-5$ depends ) it can help u to boot into EDL mode ( same effect as using testpoint ), then use MSM Download Tool ( which specified for your 8T variant ) to rescue ur device!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Brian Moore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 443
