Ga door naar hoofdinhoud
Het Bose 3-2-1 Home Entertainment System is een serie op dvd gebaseerde thuismedia-systemen in de Bose 2.1 home theater-lijn. Het Bose 3-2-1 Home Entertainment System werd tussen 2001 en 2006 verkocht en was verkrijgbaar in de kleuren zwart en grafiet.
91 Vragen Bekijk alle
Horrible screeching sound - why?
Hi, it’s a Bose Wave radio/cd player I have, but the model didn’t come up, so I had to choose this category. It has some scratchy sounds emanating from the rhs speaker, then it’ll play cd or radio for about 10/15 seconds, then it starts a dreadful screeching sound that curdles the blood and I have to pull the plug out quickly. Does this sound repairable and if so, is it a beginner’s job and what parts would be needed please? Thanks for any advice.
Is dit een goede vraag?
Score 1
2 opmerkingen
I have the same issue. The question does not seem to be answered. I will check for any leaky or bulged capacitors. It will be a few week before I can look into this. Hopefull the Solution is to replace. Andrew S is this something you have solved? How do we get and replace the capacitors?
door
@bearsel This is not something I have solved yet, merely a guess based on the 2000's capacitor plague. If the capacitors seem to be blown and/or check bad on an ESR meter, we can use the brand, series, and dimensions to find equivalent capacitors on DigiKey, Mouser, or another distributor with cheaper shipping to your area.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Can you open up the radio and check for any leaky or bulged capacitors? I have attached a picture below.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Hilary zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 302
