Ga door naar hoofdinhoud
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 Vragen Bekijk alle
Power connector pulled off motherboard and metal pieces are missing.
Hi, my problem is that I removed the power cable and the connecter on the mother board came off with the power cable. The metal bits connected to the power connecter have came off and I no longer have then. Is their anyway I could fix this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You could
  1. Take the connector off and solder both wires directly to the motherboard, or
  2. Salvage the metal bits of another connector(from scrap electronics), insert those pins into the holes on this connector, zolder the pins onto the motherboard (slide the plastic piece up), slide the plastic piece back down, and reconnect the needed components.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thankyou so much!!!
door
Voeg je antwoord toe
brittdunn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 214
