Ga door naar hoofdinhoud
TI-84 Plus calculator support.
20 Vragen Bekijk alle
Been charging for over 8 hours, light indicates still charging
So absolute disclaimer; This calculator worked fine in high school for me. However, it’s been around 4 years and as such the calculator has been sitting in a box unused for that time. I’m trying to see if it still works to sell it. At the time I’m posting this it’s been charging with the amber light indicator for 21 hours. Over this time I’ve tried turning it on multiple times with no luck. Should I let it continue to charge until I get a green light or is something wrong?
Is dit een goede vraag?
1 Opmerking
It's important to let us know exactly which TI-84 Plus you have. What is the calculator's full name at the very top?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The TI-84 Plus uses 4 replaceable AA batteries. Turn the calculator on its back and remove the battery cover, then remove and replace the 4 AA batteries. If there is corrosion in the battery compartment, use a paper towel with vinegar to clean it off. If you’re having trouble, you can follow the teardown guide up to step 5.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jodie Lynn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 246
