Ga door naar hoofdinhoud
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Vragen Bekijk alle
Computer crash then no signal on monitor
My game crashed while playing FIVEM and it wouldn’t force close and my pc wouldn’t turn off so I hadda hit the boot switch on the back and when I turn it back on everything runs but doesn’t turn off and no hdmi display I checked hdmi cables and monitors it’s coming from my pc just don’t know wtf is wrong with it , I also seen ppl say they replaced the PSU and I think that’s what’s wrong cause I have a corrisair 650w and other people have the same problem w same psu
Is dit een goede vraag?
1 Opmerking:
Hi,
More information is needed to help you.
What is the make and model number of the PC or the motherboard if a custom build?
Make and model number of GPU if a separate card and not integrated with CPU?
door
Voeg een opmerking toe
1 Antwoord
From my experience this can be a sign of a bad Graphics Card. I would unplug it from your mother board and if your desktop has a Display connection such as HDMI or VGA on it then plug it directly to that and boot it up. The only time this won't work is if your Processor doesn't have integrated graphics or your motherboard doesn't have a display connection on it.
Also could you get us the model of your desktop, motherboard, gpu, cpu this might help us get you a better answer/solution. Thank you
Was dit antwoord nuttig?
Voeg je antwoord toe
smitty boi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 55
Altijd: 687
