Ga door naar hoofdinhoud
Reparatiehandleidingen en probleemoplossing voor e-readers van Rakuten Kobo
Kobo - Replacement button
I’m trying to find a replacement button for my Kobo Ereader, the rubber went brittle and crumpled :(
Is dit een goede vraag?
2 opmerkingen
What model is your Kobo e-reader?
door
It's a 2010 Kobo WiFi
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Most of them have very generic buttons found in many devices, but usually requires soldering to replace them. Heat station and an iron would be requite usually.
If it’s the type of button I’m thinking about you may find some on digikey or amazon sometimes.
Can you send a picture of the button?
I hope this helps
Was dit antwoord nuttig?
Did you find a solution? I have a white Kobo 2009 (no wifi). The rubberized square button on the front has deteriorated and crumpled too.
https://kolico.ca/tmp/kobo1-IMG_20210916...
A closer look:
https://kolico.ca/tmp/kobo2-IMG_20210916...
:( This is a sad time for me.
Can anyone think of a suitable hack?
2 opmerkingen:
I have the same problem, would love to hear a solution
door
Can we not get a replacement button or do we thrash the economy reader?
door
Why does this say solved when it clearly isnt?
Same issue, same side of the button even.
I did find this, though it's not a soft button, but it's certainly an option? Haven't tried it yet though, need to talk to a friend with a printer.
https://www.reddit.com/r/functionalprint...
Voeg je antwoord toe
Caitlyn Patterson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 80
Altijd: 4,505
