Ga door naar hoofdinhoud
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Vragen Bekijk alle
13 inch MacBook Pro 2014 fails Apple Service Diagnostic
Running Apple Service Diagnostic (OS version) test suite v.3S162 on a 2014 13" MacBook Pro (3.0GHz version, MGXD2LL/A), it says FAILED on one test:
Thermal Interface - Processor:Processor0: Extended TIM Test 75 Percent GB (test #16) - Extended TIM Test 75 Percent GB - Check that CPU is properly attached, using product spec theta dh + 75 percent guardband.
[1 minute 24 sec] ERROR -- 8 [Plimit not as expected.] -- TEST FAILED
[Last line in eye-catching red.]
I ran the test suite three times, with the same failure reported every time. I don't know exactly what this means, but it looks like something about how the CPU is seated on the logic board? Could this be repaired? (Repair instructions here only cover removing/replacing the logic board, nothing deeper.) Unseat the CPU and then reseat it with new thermal paste? Beyond my skills, but I'm wondering if it's salvageable. Can anybody elucidate?
Thanks,
Andrew Main
Is dit een goede vraag?
2 opmerkingen
Does the computer power on?
door
@andrewsawesome Yes, it powers on, seems to run okay. But I only just got it, haven't used it for anything, am testing it to check it out. Wondering now just how much of a problem this is, if it might become a serious problem in the future. Apple Service Diagnostic is the in-house testing suite Apple used for this model; I figure if you took it to an Apple Store for them to evaluate and it showed this problem, they'd probably say it needed the logic board replaced. But I'd like to know more about it, hope somebody here might be knowledgeable.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would try a different approach as Apple Service Diagnostics can mislead if you are not using the correct version.
I find TG Pro is more useful and offers a deeper view of things.
TIM - Is Thermal Interface Material (thermal paste). ASD is also testing the delta of heat transfer between the CPU thermal sensor and the heat sinks fin exhaust air. Basically, that includes the heat sink.
So I would first install TG Pro to get a baseline, Then clean the fans and heat sink fins getting all of the dust built-up out to make sure the heat is being properly transferred.
Review TG Pro again and if needed I would clean off the old thermal paste and apply fresh paste. Make sure you apply it so its only on the silicon chip not on the Green carrier and the small SMD devices on it as the paste can affect there function. Remember it doesn’t take much a dot about the size of the diameter of a pencil and less than .5 mm in height is all that should be needed. Its better to test things out with less then too much!
Once again monitor TG Pro and if you still don’t see any change replace the heat sink unit.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks, Dan; just the kind of info I was hoping for.
So far as I know, ASD v. 3S162 is the correct version this model MBP. I've never tried a version of ASD on a different model than what is listed for it; I just assumed it wouldn't work. Now I'm curious; I'll give that a try.
Anyway, TGPro looks good, I'll give it a try also.
Actually, I've already sent this 13" MBP back to the people I bought it from. It was advertised as "excellent", but had significant, very visible external damage – and then ASD reported this failure. In addition, the EFI version of ASD crashed (twice) while testing the RAM. (Odd, since MemTest86 showed no errors on its default – 6 hour – four passes.)
This level of repair would be beyond my skill anyway, but maybe the dealer will be up to it.
Anyway, I'm learning more about how to evaluate the several MacBooks I'm planning to buy in the next weeks. Thanks again.
door
@HandyMac - Happy to help! Don't forget to accept the answer - Thanks!
door
Hey HandyMac
TIM sounds like Thermal Interface Module, which I think is likely related to the heatsink / fan on this unit. CPU should be soldered onto the MLB, so I doubt there’s any way to re-seat it, but it probably isn’t an actual CPU problem. I suspect you may have one of a couple of problems - either the fan is not cooling the CPU the way the computer thinks it should be or one of the thermal units on the system somewhere is reporting that something regarding the heatsink / heat dissipation is out of spec. Did you just repair this system and then come across this error or were you running ASD on it as a preliminary step?
Score 1
1 Opmerking:
Thanks for your response.
“CPU should be soldered onto the MLB.” Oh. Haven’t looked at it. CPUs used to be socketed, but then so did RAM. I dimly remember seeing instructions somewhere about how to resocket a CPU.
Just got this computer, running ASD to check it out, along with other tests, to determine if it’s a keeper. Which it probably isn’t, but I’m just curious what this particular error is about.
door
Voeg je antwoord toe
HandyMac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 135
