Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Vragen Bekijk alle
iPad Mini 2 boot loops when plugged in
I have an iPad mini 2, and when I plug it in, it immediately shows the Apple Logo, and then turns off after a couple seconds. I would assume I need a new battery because it turns off right after it’s unplugged, but is there any way to know for sure? Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like a bad battery, Just replace your battery and check. If that doesn’t fix it bring it in to a reputed micro-soldering company for them to take a look at it. Cheers!
Was dit antwoord nuttig?
Voeg je antwoord toe
Boden Laman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 47
