Ga door naar hoofdinhoud
Repair guides and support for the 24" iMac with M1 chip, introduced in April 2021. Identified by model A2438.
Is glass bonded to display?
Ok, i’ve managed to flip this iMac off my desk while try to use the height adjuster (a 2” thick trade paperback) and have a cracked glass panel. Computer is useable but, well, each time i look reminds me of my stupid. Local mac independent quotes about $720 to replace, $599 of that being front glass. So is front glass affixed to the display, are they sellling me glass only or glass and display?
Is dit een goede vraag?
Score 2
1 Opmerking
Hi, the glass its fixed to de screen, its all one piece, thats why its so expensive to fix. I’ve tried to find the replacement part but I cant find it :( Could someone help us please?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Unfortunately this model continues the trend of fusing the glass to the lcd that Apple was using on their previous models. If you want to fix the glass, you will need to replace the entire display assembly, hence why the repair is so costly.
Was dit antwoord nuttig?
Score 7
https://es.aliexpress.com/item/100500355...
Voeg je antwoord toe
Dominic Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 54
Altijd: 2,209
