Ga door naar hoofdinhoud
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
389 Vragen Bekijk alle
Vraag afgerond
MacBook Air not turning on
I have a 2017 13” macbook air that isn’t turning on no matter what i try. Ive attempted to reboot, enter recovery and safe mode, let it charge (charger light is on and orange), disconnected then reconnected the battery, cleaned dust from the inside and tried resetting the SMC. I even tried gently hitting the four corners and rubbed the keyboard side to side as suggested in a few other forum posts but nothing has worked.
There’s no startup or shutdown sounds, no sign of the fans being on and the display isn’t on a low brightness.
I’m not the best with computers but looked at countless forums and none of the solutions have worked for me so is there anything else i can try before looking to get it professionally repaired? There has been no other problems with it so was surprised that it wouldn’t turn on this morning (was working fine the night before).
thanks for any help and replies !!!
Specs…
MacBook Air "Core i5" 1.8 13" (2017*)1.8 GHz Core i5 (I5-5350U)
link to full list down below…
https://everymac.com/systems/apple/macbo...
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
I don’t have any solution to this, but I am in the same situation too. I even ordered a used IO-board and replaced that, to no avail.
I have also switched some cables, detached the keyboard cable, started powering the machine up with the power pads. Nothing works. The charger light is lit just as Millie’s.
My guess is that the motherboard is broken somehow. If someone have a potential fix I’m willing to try it out.
Was dit antwoord nuttig?
turning on logo coming after sh down
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 168
