Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
I think my 2010 15" MBP logic board is fried
I pulled my laptop out of my backpack a few weeks back and it would not power up. It’s a mid 2010 15” Unibody i7 2.66 GHz with 8GB RAM and two SSDs (1.5TB total).
When I press the power button:
  • I don’t hear fan spin up
  • The screen backlight does not turn on.
  • There is no boot chime
  • The status indicator light on the front of the top cover does, in fact, turn on.
  • Magsafe turns green and then amber when battery is connected. When the battery is disconnected it is only green.
With the case open, I have been able to get the fans to spin by disconnecting the battery and first pressing the power button, then plugging the magsafe in. I don’t think I’ve been able to reset the PRAM and SMC successfully as it doesn’t seem to get past post. Also, I hooked the laptop.
I’m not a logic board repair person by any means, but I’m thinking maybe the thermal paste on the GPU and CPU needed replacement and those components may have overheated. I noticed the laptop got pretty warm before this failure happened.
Any and all help is appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
After looking up some more solutions on the web I ended up baking the logic board in the oven and that fixed it. I think it was the GPU and it needed a reflow. It was down for weeks and I’m typing this message on it now. Thank you very much for the help.
Was dit antwoord nuttig?
Het nuttigste antwoord
Go for a spontaneous restart. Disconnect the mag-safe then the battery from the logic board. Press and hold the power button for 10 seconds. Reconnect the battery then the mag-Safe. It should restart on its own.
Score 2
1 Opmerking:
Thank you for the help.
door
Voeg je antwoord toe
JDiddy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 53
