Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1199 Vragen Bekijk alle
Keeps restarting after update
Hi, My phone got stuck on a bootloop after battery died so I restored and updated my phone to 14.7 but after this update my phone restarts every 3 min or so I read the panic log and it was thermalmonitord missing sensor mic1 error. How can I solve this problem ? I tried disconnecting every flex on motherboard but nothing seems to work.
Is dit een goede vraag?
1 Opmerking
I just solved it by downgrading to 14.6 from 14.7 It sucks not being able to jailbreak but atleast I can use my phone now.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
It was bad battery all along.
The phone requires a working battery sensor to function, otherwise it can’t get battery temperature data and trips off every few minutes as precaution.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Some say it's caused by charging port. I'm not really sure to buy which one
door
If it shows missing sensor mic 1, it's supposed to be charging connector flex. Unless there were some additional info on the panic log which you didn't state though, that's why it pays to do a screenshot sometimes.
There are several common reasons why an iPhone might keep restarting after an update to iOS 16.
Here are some common causes:
  1. Force restart your iPhone
  2. Update the software on your iPhone
  3. Remove the SIM Card and reinsert it
  4. Determine if an app is causing your iPhone to restart
  5. Delete all outdated apps
  6. Update all apps
  7. Clean up your iPhone
  8. Reset all settings
  9. Check for a hardware problem
  10. Restore your iPhone as new
Read the following blog for more information:
Voeg je antwoord toe
Kuzey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 119
