Ga door naar hoofdinhoud
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
iPad stuck in update mode, can’t even get in dfu mode
my home button was broken a while ago and I tried the other ways of getting in dfu mode nothing worked, I plugged into iTunes for windows and it still didn’t detect it, since i have to tap trust computer, which I can’t do cause I’m in update mode, it’s been stuck like this with the progress bar not even showing a pixel of black(the progress bar), at the time of writing, also when I plug it into iTunes it gives me error 0xe8000065 after a few minutes
EDIT: I have now gotten the iPad to the plug into iTunes black screen but on the middle of updating, it disconnects and says error 2003
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You need to do a hard restart but with home button not working you can not do it you can try . But if you keep screen lights on and kill the battery then bring itunes up plug dead ipad into your computer when it boots itunes should catch the update and repair the problem with update but with home button not working last time i saw that the battery was leaking acid in the bottom of ipad you should lift screen and look if you dont know how take it to a place that replaces screen and ask them to look in it
Was dit antwoord nuttig?
Voeg je antwoord toe
Void4Games zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 105
