Ga door naar hoofdinhoud
Windows 10 is een hoofdversie van het Windows-besturingssysteem. Het werd uitgebracht in 2015.
Vraag afgerond
How to stop McAfee pop ups notifications on windows 10?
Hi, McAfee pop ups are coming time to time on my windows screen between the programs. My McAfee subscription has finished last month and I am facing MacAfee pop up issue. Can I stop it? Help me
Is dit een goede vraag?
Score 12
7 opmerkingen
Hi,
Have you tried uninstalling the program?
door
isnt that a virus
door
@ jacob muehlberg
McAfee is a 3rd party anti virus program (see list) that has the habit of notifying you when your McAfee subscription needs renewal and unless you completely uninstall it, because you don't want to use it anymore, they persist
door
ah ok i must be thinking of something different my bad
door
Jag vill inte ha skyltarna som kommer upp ta bort virus
door
2 commentaren meer tonen
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
In order to remove McAfee from your system you want to open windows settings then open the apps category, now in the apps and features tab scroll down until you see McAfee antivirus listed as an app now click on it and then click uninstall then select to allow McAfee make changes to your system and then follow the instructions on the uninstallation wizard (if there is one) to finish uninstalling McAfee.
Was dit antwoord nuttig?
Score 6
10 opmerkingen:
I did not have the McAfee in my system, however, I had WedAdvisor by McAfee, this was the source of the pop ups. So scroll all the way down to see, if you have this installed as well, even if not McAfee. Uninstalling it did the trick for me.
door
Thank you! Thank you! Thank you! Finally the answer I needed to get rid of the annoying McAfee pop-up ads. I really appreciate your help with this - It worked like a charm and was easy to do!
door
The only McAfee app I can find in my Apps list is McAfee Security Scan Plus, and it is not possible to uninstall it - the Uninstall button is grayed out. There is no WebAdvisor in my Apps list.
door
Thank you, Tanja K. Uninstalling the WebAdvisor did the trick for me too!
door
worked for me too! So glad to see this, Thank you, Thank you
door
5 commentaren meer tonen
I FOUND THE ANSWER. Search for the services app with the windows button and open it up. Even if you have McAfee uninstalled it will still show up in here as running! Stop the service, go into its properties and set it to disabled!
Score 4
1 Opmerking:
Thanks Mattias! Will the service stay disabled after restarting the PC?
door
Hello there
there are many types of pop ups such as renewal pop-ups, alerts and notification pop ups, threat detection pop ups etc. Stopping these pop ups may result in trouble instead you should try to limit or change alerts settings.
if the mcafee subscription is expired then you should know how to stop mcafee pop ups using the method provided in link.
the reason you get pop ups from Mcafee even after uninstalling Mcafee is web extension and leftover files. when the program is removed but has certain leftover files or web extensions it might affect the web browser or system and in result it may give our annoying pop ups.
hope this helps your Question.
Score 3
9 opmerkingen:
I've uninstalled Mcafee and still have pop ups. How do I stop them. You explain why I have them above but not how to get rid of them.
door
I love how no one has actually answered your question thoroughly 😅
door
C,ick Ctrl/Shift/Del to clear cache and cookies. That should do it!
door
door
Check for WebAdvisor (by McAfee) in the installed programs. As it has a different name, I missed it at first, but uninstalling this as well could help. It was the source of the spam pop-ups for me.
door
4 commentaren meer tonen
Start-> Settings-> Apps, scroll down until you find McAfee and uninstall it.
If you want to disable pop-ups, you need to set the settings in McAfee and / or turn off all notifications. For notifications, click on the icon to the right of the taskbar.
Uninstall McAfee software via windows setting. Still if you are getting pop up, remove McAfee extension and plugin. And another ways is to stop pop up is, go to setting > privacy and security > site settings and stop notifications from websites.
The Mc Afee popup is not from Mc Afee. I have not had that program in many years. This is scam. I have cleaned the PC, but it still pops up. I have Window 10
Lars
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 43,996
