Ga door naar hoofdinhoud
Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
165 Vragen Bekijk alle
Black line on the bottom of the display and then restarts
I replaced the screen on my personal device and went for the cheaper LCD option, However I am noticing when I am doing graphic intense games such as pokemon go and I am in direct sunlight or charging with a fast charger, a black line will appear and the phone will freeze and then the phone will restart about 5-10 seconds later. I was wondering would this be because of the LCD display or does the display that I purchased have an issue that shouldn’t be there when you go for the LCD option.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Bonjour,
C’est tout simplement votre LCD qui est d”défectueux, il faut le faire remplacer et faire jouer la garantie la ou vos l’avez acheté.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you for that, in your opinion do you think getting a new lcd display is a good choice or should I wait until I have the money for a OLED display, which is about $200 more in my currency.
door
If you are ready to tell the difference an OLED is always better, but if you are in a hurry, the LCD will do the trick.
door
Voeg je antwoord toe
Colin Peart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 61
