Ga door naar hoofdinhoud
De HP LaserJet CM1415fnw is een multifunctionele kleurenprinter geproduceerd door Hewlett Packard.
Having several paper jams
Every thing seems to be working fine with the printer from a communication point; however, every 2nd or 3rd piece of paper jams as it is coming out. I have check to ensure no paper is clogging port where paper is being dispensed and cannot understands why it wrinkles.
Please advise,
Paul
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
you may need to dig a bit deeper. there is a roller that rolls the paper through on most printers. Some times there is 2-3 of them. And it could be at any of those that is the problem. I believe on your printer you can pull the back cover off to get a better look at all the rollers. you may have a small piece of torn paper that only comes around and causes issues every so often.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Paul Staples zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 514
