Ga door naar hoofdinhoud
3rd Generation high performance tablet computer released by Apple in October 2018. Models A1876, A2014, and A1895.
64 Vragen Bekijk alle
IPad Pro backup problem
Hi.
I have an iPad Pro model 2018 - 12.9 inches.  I try to backup all the data I have on it.  But about a year and a half ago my screen was partially broken, but the screen works just fine.  And I also think that the charging port has been damaged with the time I’m using it.
Because every time I connect it to a computer to backup the iPad then the computer does not recognize the iPad at all, not even with another cable.
 So my question is, how can I backup my iPad if the charging port is screwed, and the screen is broken so that it is also problematic to replace a charging port without also replacing the screen, something I do not have money for at the moment.
I would be happy for your help please, because it is very very important for me to backup the data I have on the iPad.  I would be very happy for your help!
TY ALL!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You use iCloud. If the data is that important to you, a few dollars per month is nothing.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Ty very very much buddy!
door
I don't know if this will work for you. There is a free iPad backup tool called MobiKin Assiatant for iOS. You may try it.
Voeg je antwoord toe
I.k zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 54
