Replaced the power and volume control cable but still not working
I replaced the power and volume control cable but my power button, volume buttons and flash still are not working. iOS 15 beta
Is dit een goede vraag?
This seems strange as the problems you are facing are on different circuits. I would check the logic board connector and the components around it under some magnification.
The power button works by shorting this pin to ground. Try this with a pair of tweezers to rule out the buttons and flex.
Was dit antwoord nuttig?
is there another way to do it with much less risk to my phone? I'm not very good at precision so i dont trust myself to do that without killing the logic board
@senharampai You can measure that pin and see if it has 1.8V going to it. Besides that the only other way would be to put the logic board into iPhone 7 housing or try another power button assembly.
@imicrosoldering alright, thanks for the input. I’ll try asking someone better than me to do it. If there’s no voltage then does that mean that no button assembly for that part will work at all?
@senharampai Yes, no voltage would indicate faulty component on logic board.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 31
2 opmerkingen
So it boots fine when charge cable is connected?
door Chris Stables
@imicrosoldering yes it boots up and works just fine except that the volume buttons, mute switch, flash and power buttons don’t work
door Sen
