Ga door naar hoofdinhoud
ASUS TUF back panel not coming off.
My ASUS TUF FX505DT back panel is not coming off…i did unscrewed all the screws, but the back side(near the radiator) is seems to be stuck..i tried every ways…pls help…i just want to clear my laptop.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hey Sleepy,
Do you have a spudger or old creditcard/giftcard? You can use those to wedge between the plastic. Just make sure not to use anything metal, like a screwdriver, because that will jack up the plastic.
Hope this helps.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
ok thx i will try..
door
here is a screen placement video on YT i found, good luck!
https://www.youtube.com/watch?v=bXg550tY...
Score 1
9 opmerkingen:
What i meant was back panel
im sry
door
@Sleepy Guy back panel? on the screen or the keyboard side of the laptop?
door
@logixal keyboard side
door
@Sleepy Guy roger, so if you watch the first couple minutes of the video it still goes through the process of removing that back panel.
door
4 commentaren meer tonen
Voeg je antwoord toe
Sleepy Guy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 187
