Ga door naar hoofdinhoud
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
iPad bootloop after throwing due to Roblox server maintenance.
My iPad got trapped in a bootloop after this story: I was playing a game on roblox, but the server went on maintenance. I threw my ipad many times across the room in anger. It worked fine, but it bootlooped after i came back home. It bootlooped and force rebooting did not help ether. The worst case scenario is the SSD broke and my data and the OS is gone. I think my logic board or bios chip is loose. I do not want to lose ANY data. I did not back up iCloud due to the space being full (5GB) I have 128 GB black model.
Edit: It was just a botched update. No physical damage whatsoever. I have a case.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Just connect to iTunes, and enter Recovery Mode, and hit update. After, open photos and go to the top of it, and charge your device, but keep it on. This will recover all of your photos. It worked for me.
Was dit antwoord nuttig?
Score -1
Het nuttigste antwoord
Fix your stupid anger issue first. If losing some data fixes your tantrum, it’s a cheap solution.
As for the iPad damage, if you need to ask, you can’t do it.
Score 1
2 opmerkingen:
I clicked update with iTunes, and now it works perfectly fine,my data intact. Learn some manners. I'm reporting you.
door
@The Mariocrafter So your anger issue will just wreck your iPad next time.
My manners are reserved for sensible people, you do not qualify.
door
Voeg je antwoord toe
The Mariocrafter Alt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 368
