Ga door naar hoofdinhoud
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Vragen Bekijk alle
2017 MacBook Pro Doesn’t Restart
I decided to upgrade the 128gb SSD on my Mac to the Sabrent 512GB Rocket NVMe PCIe M.2 using this adapter https://www.amazon.com/dp/B08RCMJJHX?ref...
I was able to format and install MacOS Big Sur successfully, however during installation the system wouldn’t automatically reboot instead just shutdown until I pressed the power button. Also when I restart from Apple Logo in the top left corner the system wouldn’t reboot until I pressed the power button and I’m thrown two errors that says, “You shut down your computer because of a problem” and “Your computer was restarted because of a problem.”
Is dit een goede vraag?
3 opmerkingen
Put the original drive back in, does that work?
door
Yes that fixes the problem, so it’s definitely the 512GB SSD. Should I return the SSD and adapter for another brand?
door
@alexchung - Yes!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sadly, here’s no options other than another Apple SSD as its a custom part!
Here’s one source Apple 512 GB SSD or Apple 1 TB SSD
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Alex Chung zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 135
