Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
372 Vragen Bekijk alle
I replaced hard drive with SSD in 2019 without Thermal Sensor Adapter.
I replaced hard drive with SSD in 2019 without having the Thermal Sensor Adapter. I have it now and want to know if the installation process changes for me installing it into my imac 27 2010. Do I need to reset any of the SMC or prams? Any other input welcomed.
Is dit een goede vraag?
1 Opmerking:
Please rephrase your question. It sounds like you installed the new SSD into another machine and are now moving it. Did you get a runaway fan when you installed without the thermal sensor?
door
Voeg een opmerking toe
1 Antwoord
The 2014 models onward don’t need the in-line sensor when running High Sierra or newer which is why your newer 2019 didn't need it, but your older 2010 will.
But! You might hit a SATA speed issue as the older iMac is only SATA II (3.0 Gb/s) so the drive needs support this slower I/O. Most drives today are fixed SATA III (6.0 Gb/s) which is to fast. Some drives are auto sense, and will match to the systems SATA ports I/O speed. Review the drives spec sheet to see what it is able run at.
Was dit antwoord nuttig?
Voeg je antwoord toe
Dxx zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 24
