Ga door naar hoofdinhoud
Hi, I am unable to power on
Unable to power on my laptop,even after battery removal
Is dit een goede vraag?
Score 2
2 opmerkingen:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
door
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
door
Voeg een opmerking toe
1 Antwoord
Hey Wow,
Are there any indicators when you plug in in to AC power?
Do any lights show up?
Was dit antwoord nuttig?
Voeg je antwoord toe
WoWsOmE ViN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 352
