Ga door naar hoofdinhoud
A 10 speed mixer made by KitchenAid in 2006.
27 Vragen Bekijk alle
Kitchenaid 600 making a spinning sound, but not actually spinning
When I turn the gears on, sometimes nothing happens, but if I turn it up high and jiggle the gear, the engine will make a sound, but nothing that is visible will spin. I’ve taken it apart, but now don’t know what to do! Ha! I’m eager to fix it but I’m a noob.
Any thoughts would be much appreciated!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Sounds like the motor is working fine, perhaps while you have it apart follow the mechanical connections up to the source of the problem? Might help to stick in one of the mixer things and spin it manually to see where it isn’t connecting.
Was dit antwoord nuttig?
Voeg je antwoord toe
Elizabeth R Tolmach zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 38
