Ga door naar hoofdinhoud
Repair information for the Asus VivoBook Flip 14. Model numbers: TP412U/TP412UA/TP412FA. Released in 2018.
13 Vragen Bekijk alle
touchpad not working after cleaning
i have a asus vivobook x512 laptop i used a screen cleaning solution to clena the touchpad and now its not working when i heat the touchpad using a dryer it starts working then again stops on the next boot?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Some moisture got in a place it shouldn't and seemingly it did little or no damage (if the function is coming back). Please it open with the keyboard DOWN in a warm dry place for a while, should help.
You should never turn on a device after it has had liquid on it. Not until you are completely sure that all of it has dried up and been cleaning out. Which can take days.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sarthak Chimaniya zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 32
Altijd: 483
