Ga door naar hoofdinhoud
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Vragen Bekijk alle
Retina Display Spot and Pixel Problem
Hi everyone,
I have a spot and pixels problem on my screen for 1 year. My macbook is late 2013, 15''. i Open a black or gray pages, i see some tingle on my screen. I have added the photo of my problem. It is not visible on white pages. In all black screens, it is visible and the spots’ locations are always same.
By the way, i can’t see this spots and pixels on the black opening screen. After i open the computer and few minutes later, they are becoming visible.
Are you anyone else having this problem before?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The display itself appears to be showing signs of aging. This will likely get worse as time goes on and the solution is to replace the display.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Yep! Onur needs a new display assembly! The cause is either pressure and/or heat. What happens is the liquid crystal material has degraded from the glass plates its caught between has uneven pressure or what overheated by leaving out in the hot sun.
Here's the needed part MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly and the guide MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement
door
Voeg je antwoord toe
Onur Mutluay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 152
