Ga door naar hoofdinhoud
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Vragen Bekijk alle
I replaced my battery and now MBP will not power up.
MBP will not power up after battery replacement. Plugged in with a known good cable and charge adapter (I also tried another known good adapter and cable). The power chime does not chime when it is plugged in. I checked all connections that were removed in the battery swap and all appear to be correctly on. I even swapped the old battery back in (MBP was working on old battery before I replaced it) and still nothing. A couple of years ago the MBP had suffered a spill incident that wiped out the keyboard. I have been using it since with an old iMac bluetooth keyboard. Only reason I changed the batteries was they were swelling up.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I think it’s time to find someone with deeper Mac skills. You likely need your logic board repaired here.
Was dit antwoord nuttig?
Voeg je antwoord toe
Steven Wonder zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 29
