Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Can I fix a broken connector housing/mount?
I was trying add new thermal paste and when I was removing the logic board, I accidentally cracked and then broke off one of the connectivity housing that (I think) goes to the disc drive. The cable/wire seems fine. It’s the mount that held the red cable
that is broken. Is this part replaceable/repairable? I’m having trouble finding a part that would match. Any ideas? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It’s the socket for the left speaker similar to the fan socket. It can be soldered back to the board if you find the part. You can harvest it on a Macbook donor board or buy it on eBay. Any tech can solder back the socket for cheap, only six micro solder to do on this part. Don’t try to glue it on the board, the 4 front pins must make a good contact to the pads and only solder can be used in this case.
Was dit antwoord nuttig?
Voeg je antwoord toe
MyMusic Nakamura zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 32
