Ga door naar hoofdinhoud
Buttons not clicking enough
Hi!
I did a complete housing swap on my iPhone, and after putting the side volume buttons in I noticed that one clicks normally and the other one is kinda loose. Any fixes? I checked and all the screws and everything is as they should be
Thanks!
Is dit een goede vraag?
2 opmerkingen:
Do you mean the screw hole thingy? The place where I put the screw in? It’s kind of extruding from the housing, even if just a fraction of a milimeter.
door
No, just google” little metal spacer beyond buttons on iPhone “ and you will see what I mean
door
Voeg een opmerking toe
1 Antwoord
Hi, take a look at the side of the volume button that is going in the housing if there is a small round spacer attached ( don’t know if it is the right word). It is a very small round metal thing to fill up the space. This could be the problem why it doesn’t click. For a example search on google for :metal spacer behind button on iPhone.
Was dit antwoord nuttig?
Voeg je antwoord toe
Simon Kapicka zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 28
