Hanging on Apple logo after repair
My iphone 7 plus housing was all beaten up and before selling it I thought I’d swap it out (big mistake). I carefully swapped all the components into the new housing and when I powered it up I’m stuck in a boot loop. hangs on apple logo for approx. 1 min and then appears to reset and repeat.
itunes will not detect it, even when I get it into DFU mode.
Just plugged it into smart wall plug and it is not drawing any power so clearly isn’t charging. Soon the battery will be dead.
I get no vibrating feedback from pressing the home button.
I’m assuming I have either not put something back together properly (but I have triple checked everything) or I’ve damaged something in the process of disassembling and reassembling.
I did tear a bit of a hole in the black material wrapping the battery… and it has that nasty chemically gluey smell. I know this isn’t ideal but I figured it wouldn’t be the cause of this problem…? Also the tape snapped so I had to pry it out which did involve bending it a bit
Any ideas on how I can diagnose the problem?
Is dit een goede vraag?
