Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Vragen Bekijk alle
Broken speaker connector on logic board
Hello.
I’ve broken the plastic part which holds the flex cable in place, off the connector for right speaker on the logic board of my A1708 MacBook Pro. Anyone knows if there is maybe an easy fix for this aside from replacinig the whole logic board?
Damaged connector is outlined on the first picture and normal un-damaged one on the second picture, for easier understanding.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Someone with the proper tools and skills can replace the connector.
Where are you located country and nearest city? Maybe we can point you to someone local.
Was dit antwoord nuttig?
4 opmerkingen:
I'm located in Europe - Slovenia in the city of Maribor.
Does the whole connector needs to be replaced, or is it possible to just replace the plastic part?
door
@mat3jko - Sorry I don't know of anyone in Maribor. Right now you likely can't travel do to the scourge messing us all up. Are you able to get to a larger city?
Sadly, the whole connect needs to be replaced.
door
@danj
Yes, I can get to a larger city in our country, but there is only one larger than Maribor anyway. :)
door
@mat3jko - Ouch! Just didn't realize Google Earth didn't make it the largest. You'll need to do some searching for someone skilled in micro soldering and has access to the part (likely from a junker)
door
Voeg je antwoord toe
Matej zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 168
