Ga door naar hoofdinhoud
Model A1288 / 8, 16, or 32 GB capacity
451 Vragen Bekijk alle
iPod No power after repair
So I'm fixing my girlfriend's sister's iPod. I have done these many times before, just a cracked screen.
So after I replaced it everything went fine. She told me a few days later that the home button has stopped working. So I just took off the new touch screen to take a look. when I go to power it on and it seems to unresponsive.
I tried 3 cords, all usb ports on two computers. Nothing.
Did I short out the logic board?
Any help would be great.
Thanks.
Is dit een goede vraag?
9 opmerkingen
check your battery has output/charge with a multimeter. The experts on ipods will know better but if the home button isn't working it may be the charging port is dead/not connected, hence not charging/syncing.
door
Can I check it with out lifting the lcd?
door
Oh wait never mind I lifted the lcd.
door
Ok, So im getting a reading from the battery and a higher one when i plug in the charge cable.
door
Try reconnecting LCD an doing a reset. This may power the LCD back on. If it is recognised in iTunes this may be an LCD problem.
door
4 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I got it. I used another digitizer from a another ipod and it boots up.
Thanks to all of you who help me.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
lloyd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,336
