Ga door naar hoofdinhoud
Battery or Dock Connection!
I have an older itouch first gen, when I charge it it doesn't hold the charge, can you tell me if this is more likely a battery or dock connection issue? It does take extra effort to show when it is connected to charge... seems looser than in the past
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Being a first generation it is likely a battery. You can visually inspect the dock connector to see if any pins are missing, bent, or a buildup of debris. However, if the dock was faulty you may get no response when plugging the device in. The batteries are not made to last forever (planned failure).
This repair requires solder, but is the easiest of the touch batteries to install.
Good luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
matt119 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 380
