Ga door naar hoofdinhoud
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Vragen Bekijk alle
Vraag afgerond
Using a PowerPC iMac screen for an Intel iMac
Hi, I have a 20" PowerPC iMac G5 with a good screen but it keeps locking up.
Apart from the mechanical aspects, I wonder whether the display from this machine would be compatible with a 17" Intel-based 2 Ghz Core 2 Duo iMac that just happens to have a damaged screen.
Hope someone can help,
Thanks,
Rob
Update 16/11/2011:
Problem solved - I've bought a Power Mac!
Is dit een goede vraag?
1 Opmerking
After checking a few other postings, it seems unlikely that this screen would be compatible :(
Plan B may be to use an external monitor. I have a faithful old 15" LCD screen which has the 15-pin 'D' style of connector. With the right cable, I wonder whether this could be used as an external monitor for the Intel iMac?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
According to this previous answer I would think that it should work fine.
Good luck.
Why monitor displays a lot of lines on screen?
Was dit antwoord nuttig?
Score 3
I am using an external monitor with my iMac Intel 5,1 (EMC2118) after the internal monitor quit.
The Mac boots up in extended mode, (2 screens wide)
I took it in to the Genius Bar to see if they could switch it over to mirroring the internal monitor. The genius did it with a couple of keystrokes.
BUT,
the same command (or any others I can find) will not work with MY (original) keyboard or a couple of spares.
Apple tech support had no clue what I was talking about.
The workaround aln't pretty - I had to blindly find & drag the HD icon from the dead screen to the functioning one, then drill down to the control panel to change the display to mirrored.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 945
