Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
Where can I get SMD components
so i messed up!
was trying to fix my charging port on my switch and got it reinstalled and the pins that i could test tested good!
2 pads came off but are grounds im pretty sure. ( ill post a picture)
but when i did a full board inspection i found some SMDs were knocked off.
i think when i put it in my PCB holder it popped them off :(
does anyone know where i can find out what goes in these spots? and where i can get the SMDs?
thanks for the help!
here is the one with the missing SMDs it looks like 4 are missing :(
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The missing pads are for USB 3 communication, your Switch should work without them but it may cause problems when connecting it to a computer or phone, or it'll only work when plugged in one way.
As for the ripped SMDs, your best bet would be to buy a non working board off of eBay as a donor board.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Logixal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 296
