Ga door naar hoofdinhoud
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
101 Vragen Bekijk alle
iPad Home Button not working after Digitizer Replacement
I replaced the digitizer specifically because I accidentally broke the home button connector ribbon. I have to use the one I have (the new one I mean) or buy another. When I connect the digitizer and LCD panel, the home button does not work. I have not fully assembled the iPad yet, as I wanted to check if it worked. Do I have to fully assemble to get the button to work? and if not then can anyone see my problem?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
That looks like an iPad Air home button, which carries a different protocol and is not compatible with iPad 5.
Either that or the home button is faulty.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
That’s actually a really helpful input, when I bought it it was labeled as a digitizer for iPad 5 or iPad Air. So does this mean that it just really isn’t the right home button?
door
@Nathan Mayo That explains it, you got the wrong home button (iPad Air)
door
Voeg je antwoord toe
Nathan Mayo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 37
