Ga door naar hoofdinhoud
Stylus for the iPad Pro (3rd Generation) featuring gesture controls and magnetic attachment and charging. Launched November 2018. Model A2051.
18 Vragen Bekijk alle
The body of my Apple Pencil 2 has warped over time.
The body of my Apple Pencil 2 has warped over time. It is becoming concave on the flat side, making it not able to charge when attached to a case. It still charges when directly attached to the iPad. The concave curve is noticeable.
The pencil has not been dropped or bent or otherwise mistreated. I think the constant downward pressure from use has slowly warped the pencil over time, and I use it a lot.
If there is a tear down of the Apple Pencil 2, can anyone tell if there is a design defect that causes the pencil to warp favoring the flat side?
Because of the unique flat side orientation for the the tap feature, I hold the pencil always in the exact same orientation, as opposed to other writing utensils and the old Apple Pencil, where the orientation of the utensil did not matter and presumably, the pressure on the utensil is averaged out randomly, as opposed to being focused only on one orientation.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Apple Pencil is very hard to repair and they do not sell Apple Pencil housing anywhere on the internet. You can buy used Apple Pencil on eBay that functions 100% and are cheaper then buying a new one.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
polywen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 398
