1998 Cheyenne C/K truck horn not working. What do I check
Horn not working when we press the steering wheel on the 1998 Cheyenne C/K extended cab truck.
What & where are the parts I should check?
Is dit een goede vraag?
Check the fuse box. Pull fuse and look for a break in the line. I wire maybe disconnected or there's a break in one of the wire lines going to the horn.
U can also pull the cover off the steering wheel. If u do u'll b able to c the problem. If it's what I think it is then the part would b cheaper at a salvage yard. There should b like 2 wires that connect to a plastic piece.this plastic piece is right under the cover. It maybe broke in half.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 322
