Ga door naar hoofdinhoud
Guides and repair information for Neato robotic vacuum cleaners.
D85 Botvac: clunking noise while operating.
D85 Botvac is working fine, but now has a loud knocking/clunking sound when maneuvering. It is intermittent. I service clean the brush and bearings almost every run. I have tightened up the wheel hubs, so that is not the issue. At a loss.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
So the clunking turned out to be the brush motor becoming loose from the brush gearbox.
I removed the gearbox from the D85 and put blue thread-locker on the motor mount screws. I also added a thin nylon washer between the main transmission gear and the gearbox.
Everything is perfecto now.
Was dit antwoord nuttig?
1 Opmerking:
where is the gear box
door
Voeg je antwoord toe
Mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 250
