SSD no longer recognized after Disk Utility erase
I have a 15” late-2016 MacBook Pro that I had used daily since I bought it in 2017. I was trying to wipe the drive as I had just sold it online, so was following Apple’s online guide to preparing it for sale. https://support.apple.com/en-us/HT201065
I got to step 7 and followed the instructions here to erase the drive. https://support.apple.com/en-us/HT208496
When disk utility finished, it restarted and showed a circle with a line through it. Being somewhat tech savvy, I booted into internet recovery but found in Disk Utility there was no SSD listed. So I made bootable copies of Big Sur and High Sierra and loaded Disk Utility through those and still no device or volume listed. I tried using Disk Utility Terminal commands to see if anything was listed, and nothing was listed that should have represented the 512GB drive.
I can’t figure it out.. and the techs at Apple are bemused. Apple is now saying the SSD needs to be replaced. I literally followed their instructions, and now they’re asking me for $680 to fix it!? Is this a known problem with old Apple SSD’s, APFS, and Disk Utility? Does this sound familiar to anyone? TIA!!
Is dit een goede vraag?
When you access Disk Utility from Recovery Mode, make sure Show All Devices is selected from the View menu. Also, can you post a screen shot of the results of running the following Terminal command: diskutil list
door Zach
Hi there. When made to 'show all devices', it still did not show the drive. Unfortunately Apple has the laptop now, so I can't post the diskutil list. But even in that, it showed only the boot disk, and a few other small drives, sometimes listing as much as 16-19 disks, but they were only about 50kB each. Not the 512GB SSD.
door zadefaraj
