Ga door naar hoofdinhoud
Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
101 Vragen Bekijk alle
MacBook Air Will not turn on
Last night I changed the thermal compound on the cpu and Now it wont boot or turn on
Is dit een goede vraag?
1 Opmerking:
Yea It broke. CPU died
door
Voeg een opmerking toe
1 Antwoord
a few things you cant try.
open it back up and check the screw holes and make sure there arent any marks on the opposite side of the holes. ( IE long screw in short screw hole and it hit a PCB component. ( Hopefully its not this ))
check your connections \ ribbons \ plugs, makes sure everything is seated properly. inspect the pins and contacts on ribbons and plugs you removed.
does it power up at all with it plugged in to power?
Was dit antwoord nuttig?
Voeg je antwoord toe
Graham Denney zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 58
