Ga door naar hoofdinhoud
Scientific Casio Calculator released August 2000. Identified by the model name FX-115MS
7 Vragen Bekijk alle
Why won’t it use the battery?
I know the version I have (Casio fx-115 ES Plus 2nd Edition) is solar powered, but I thought that it could at least store power or use it’s battery when it’s not directly under a light source? As of now, it won’t turn on unless it’s directly under a light source…
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It is possible that this model doesn’t have a battery. Many calculators are 100% solar powered.
However, if this model does have a battery, the battery is probably dead and needs to be replaced. These batteries are usually not rechargeable even though there is a solar panel. Over time, the battery will die.
If there is a battery compartment or cover on the back, then it is simple to replace the batteries. Otherwise you may have to take the whole thing apart (assuming it has a battery in the first place).
Hope this helps.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
yasmeen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 919
