Ga door naar hoofdinhoud
De Minolta X-700 is een analoge camera geïntroduceerd door Minolta. Wij bieden informatie over hoe je de batterij, sluiter, lichtafdichting en condensator vervangt.
How to fix stuck shutter and mirror?
I have this camera and today the shutter and mirror got stuck, tried to change batteries but nothing works. Please help!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
try to pull the shutter cloth in the direction of the rewind knob. You have to put one finger through the mirror case and another from behind pulling the cloth in between of the both. Do this very gently. The shutter will click and the mirror will drop.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thank you! That worked perfectly 😊
door
what if it after doing that and winding the advance lever, then taking a picture, the mirror goes up but the curtains don't move?
door
I just used this method and successfully fixed my X-300! It stucked up when it suddenly lost power during filming. Thank you so much! I searched for hours using AI but couldn't find this anywhere
door
@arborcerti97568 -
I have an XG-A and a X-700 in this stuck state (shutter button doesn't press, unable to advance the film lever. There is no film in either camera.
I assume that the lens must be removed in order to push the curtain from both front and back? Does someone have a picture of this process?
door
Voeg je antwoord toe
Eduardo Capdeville zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 60
Altijd: 3,076
