Ga door naar hoofdinhoud
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Vragen Bekijk alle
RAID card icons greyed out
My Mac Pro is a 2007 2x2.66 GHz Dual-Core Intel Xeon
Recently picked it up really cheap. I was hopefully I could use the stack of SAS drive’s I’ve accumulated.
It came without a RAID card so I picked one up on eBay and replaced the spent battery. The card is recognized and the RAID Utility reports the card is good, battery is charged and write cache is enabled but all my icons are greyed out and it does not see SAS drives when installed. It is installed in the 4th PCI slot. The RAID card I have is the second generation I believe (date on card of 2009) and it doesn’t have the iPass connector. Because I can’t plug in the iPass cable I’m assuming I have the wrong card? I had read that it would work without but that does not appear to be the case.
Any advice would be greatly appreciated.
Is dit een goede vraag?
2 opmerkingen
Who's RAID board and what are the drives? Make & Model
door
Thanks for the response. Its an Apple RAID card and the drives that are in it now are 1TB SATA Toshiba and Western Digital. My SAS drives are IBM server drives.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
OK, the SAS drives won’t work with Apple SATA II (3.0 Gb/s) controller. You’ll need to find older SATA II drives to use your RAID controller. Newer SATA III (6.0 Gb/s) drives won’t work.
To clarify, I’m talking about fixed speed drives. These are drives which only list the one data rate SATA III (6.0 Gb/s). There are a few auto sense drives which unlike the fixed speed drives have the ability to match the data rate to the systems I/O port. As an example: Samsung 860 EVO 2.5” SATA SSD note the interface line lists 3.0 Gb/s. Review the drives spec sheet if its not listed like Samsung it won’t work in your system.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Cat Juggler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 29
